crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Place the opening tool in the divot between the spine of the Chromebook and the back cover.
Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
Using the opening tool, pry off the back cover of the Chromebook
Remove the four 3 mm screws using a Phillips #000 screwdriver.
Carefully lift the top of the battery then pull it away from you to remove it.
Use a blunt precision tweezer to remove the speaker cord from the RAM
Using a Phillips #00 screwdriver, remove all six 2.5 mm screws .
Gently lift the bottom of the wifi card then pull it towards you to disconnect it from the socket.
Gently lift the top left corner of the RAM and pull upward to remove it from the Chromebook.
