This guide will demonstrate how to remove and replace the display screen on your Samsung Chromebook Series 3.
Use the iFixit opening tool to get under the front cover and pop it out of place
Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
Lift the lever to release the cable and pull the cable out.
