This guide will demonstrate how to remove and replace the front camera assembly on your Samsung Chromebook Series 3.
Use the iFixit opening tool to get under the front cover and pop it out of place
Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
Lift the lever to release the cable and pull the cable out.
Disconnect the ribbon cable connected to the front camera assembly.
You will need to flip up the little black lever to release the cable.
Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
