Samsung Chromebook Pro Screen Replacement
  1. Samsung Chromebook Pro Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the Samsung Chromebook Pro flat on your work surface.
  2. Samsung Chromebook Pro Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool between the hinge and plastic lining and pry upwards.
    • Continue to use the plastic opening tool along to the plastic lining to completely remove.
  3. Samsung Chromebook Pro Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three silver 30 mm screws connected to the screen by using the JIS J000 screw bit.
  4. Samsung Chromebook Pro Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin lifting the screen by prying upward using the plastic opening tool.
    • Work around the screen by lifting upward with the plastic opening tool until the screen is completely off.
  5. Samsung Chromebook Pro Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black and gold wire on the left side of the screen, and pry the bar upward using the precision tweezers.
    • Disconnect the wire using the precision tweezers.
  6. Samsung Chromebook Pro Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook Pro Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire connected to the right side of the screen using the precision tweezers.
  7. Samsung Chromebook Pro Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift to remove screen.
Amber Castro-Beltran
crwdns2935283:010/09/18crwdne2935283:0
933 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S15-G1, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S15-G1, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S15G1
crwdns2947412:05crwdne2947412:0
Hmm, followed this in an effort to repair a broken hinge. Fortunately, the screen didn’t break when the hinge came through the front of the monitor. Less fortunately, the prying described in step 4 totally blacked out the lower right corner of my screen. Damaged area is about the size of my thumbnail. Touchscreen still works and the machine is still usable, but so much for knowing what time it is…
Ben Caldwell - crwdns2934203:0crwdne2934203:0
Does anyone know if a XE510C24 screen can be used in a XE510C25?
The touchscreen in mine stopped working and all I can find online are XE510C24 screens.
Hoby Van Hoose - crwdns2934203:0crwdne2934203:0
does it work? i have the same issue
Jaron Larson -
Hi, my screen works, stylus work but no touch, do you know what could be wrong? There are two cables on each side. Which one is responsible for touch? Maybe that's the problem?
mpenkie - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,754
