Samsung Chromebook 3 XE500C13-K05US LCD Replacement
  1. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the case to remove it from the laptop.
  7. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the hinge that locks the gold colored display cable in place.
    • Pop the cable out and remove the hinge from the motherboard.
  8. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the ifixit spudger, raise the adhesive holding the wireless card antenna wires.
    • Raise the black and white antenna wires with the ifixit spudger.
  9. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4.6mm screws from the display mounts.
  10. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the hinge screws have been detached, open the laptop.
    • The bottom of the laptop will divide from the screen once you are able to open it a certain amount.
  11. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the ifixit opening tool to pry in between the bezel and screen.
    • You will hear some snapping as you open the bezel with the ifixit opening tool.
  12. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  13. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, raise the adhesive tap that is holding the display cable.
  14. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly raise the panel up and fold it over to uncover the display cable on the backside of the display.
  15. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the ifixit spudger, raise the hinge that is locking the gold colored display cable in place.
    • Pull the cable away from far from you to slide it out the monitor.
    • Be tender around the display circuit board, it is labeled "Do not touch."
  16. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the display cable has been detached, raise the screen up and out of the case.
Yamaris Acosta
crwdns2935283:002/07/23crwdne2935283:0
557 crwdns2915208:0crwdne2915208:0
Gateway, Team 4-4, Gonzalez Spring 2023 crwdns2935289:0Gateway, Team 4-4, Gonzalez Spring 2023crwdne2935289:0
GCC-GONZALEZ-S23S4G4
crwdns2942667:0crwdne2942667:0 335
