Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement
  1. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.6 mm screws with the Phillips #00 screwdriver.
  4. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry underneath the cable and remove the connector.
    • Remove the battery from the case.
  5. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
    • Remove the silver bracket.
    • Remove the remaining 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wire connector from the I/O board.
    • Remove the black and white wires from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the I/O board from the base of the laptop.
  9. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver port.
  10. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver port from the motherboard.
  11. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red and black speaker wires from the connector on the motherboard.
    • Use the #00 Phillips screwdriver to remove the 4.9 mm screw.
    • Repeat the first two steps for the other speaker.
  12. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speakers.
  13. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the smaller cable ribbon from the port on the motherboard.
    • Lift the clip on the connector on the motherboard and remove the larger cable ribbon.
  14. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the four 4.6 mm screws.
  15. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the motherboard from the base of the laptop.
  16. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the two 4.6 mm screws from both display hinges.
    • Lift the display hinges and remove the keyboard from the screen of the laptop.
  17. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the three 2.3 mm screws from the trackpad.
  18. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the grey adhesive tape and lift out the trackpad to remove it from the keyboard.
Caden Smith
crwdns2935283:003/28/23crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Spring 2023 crwdns2935289:0IUPUI, Team 3-3, Harley Spring 2023crwdne2935289:0
IUPUI-HARLEY-S23S3G3
crwdns2942667:0crwdne2942667:0 163
