Samsung Chromebook 2 XE503c12 Screen Replacement
  1. Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5mm Phillips #0 screws on the hinges.
  7. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug two auxiliary wires leading to the top lid.
    • Using the plastic prying tool, lift the hinge on the connector up and pull the connector away.
  8. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hinges up and separate the top lid from the bottom casing.
  9. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic prying tool, carefully pry the casing apart from the screen.
    • When prying case apart, there is a risk of screen and parts of the casing shattering and cutting you.
  10. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 5mm Phillips #0 screws holding the screen in place.
  11. Samsung Chromebook 2 XE503c12 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the screen from the device.
Jordan W Jones
crwdns2935283:002/15/18crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G3, Carnegie Fall 2018 crwdns2935289:0Eastern Washington University, Team S1-G3, Carnegie Fall 2018crwdne2935289:0
EWU-CARNEGIE-F18S1G3
crwdns2942667:0crwdne2942667:0 475
