Issues with a broken or cracked screen can be resolved by following this guide. The only tools required will be a plastic prying device, and a standard Phillips #0 Screwdriver
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
Lift the battery, and pull it up and towards you, away from the connector.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
Remove the four 5mm Phillips #0 screws on the hinges.
Unplug two auxiliary wires leading to the top lid.
Using the plastic prying tool, lift the hinge on the connector up and pull the connector away.
Lift the hinges up and separate the top lid from the bottom casing.
Using the plastic prying tool, carefully pry the casing apart from the screen.
Remove the four 5mm Phillips #0 screws holding the screen in place.
Lift and remove the screen from the device.
