Issues with battery life and a dead battery can be resolved by following this guide.
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
Lift the panel out of the way to reveal the battery.
Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
Lift the battery, and pull it up and towards you, away from the connector.
Using a plastic opening tool, pry the connector up from the contact.
Remove the battery from the device.
