If you receive an error message when attempting to use your camera, and resetting to factory settings did not fix it, then you need to replace the camera or ensure that your camera is connected to the motherboard. At times, if you've dropped your phone, the camera may detach from the motherboard.
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Remove battery with plastic opening tool or finger.
Remove the seven screws from backplate using the #00 screwdriver.
Remove the back plate using the plastic opening tool.
There is a lip on each side, and both must be pried up.
Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the antenna cable from the motherboard using tweezers.
Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
Lift the motherboard out of the base of the phone.
Using the opening tool, pry up the camera attachment from the motherboard.
