Samsung Captivate Antenna Cable Replacement
  1. Samsung Captivate Antenna Cable Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Antenna Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Antenna Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the old battery with the new one.
  4. Samsung Captivate Antenna Cable Replacement, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Antenna Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Antenna Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Captivate Antenna Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Captivate Antenna Cable Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Antenna Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the rear case from the phone.
  8. Samsung Captivate Antenna Cable Replacement, Antenna Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Captivate Antenna Cable Replacement, Antenna Cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
Drew Bentz
crwdns2935283:009/22/11crwdne2935283:0
565 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-25, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-25, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G25
Quick question, is this the antenna for wifi or cellular network?
Michael Perdomo - crwdns2934203:0crwdne2934203:0
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
Drew Bentz -
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,676
