Samsung CLP-300 Black Toner Transfer Unit Replacement
  1. Samsung CLP-300 Black Toner Transfer Unit Replacement, Black Toner Transfer Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull paper tray out and set aside.
  3. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front cover.
  4. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the waste toner container out of the printer using the handle.
    • Make sure to keep waste toner container upright to avoid spillage.
  5. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • At this point you can set the printer aside as you will only need the imaging unit to continue repair.
  6. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these two screws.
    • Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
  7. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry plastic arm away from main unit.
  8. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
    • When removing the organic photo conductor take care to not lose the small spring on the back left.
    • At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
  9. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
    • Keep toner rollers level to avoid toner spillage.
  10. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove these five screws from the top of the black toner transfer unit.
    • Remove main and smaller z-shaped plates.
  11. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these three screws from the right end of the toner transfer unit.
  12. Samsung CLP-300 Black Toner Transfer Unit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove plastic end piece.
    • Gently pull out black toner roller.
    • Insert new roller in place of old roller turning slightly to fit.
    • Be careful not to pinch small foam square when inserting new roller.
    • Cover new roller with toner by rotating roller by hand.
Heather Howard
crwdns2935283:010/15/14crwdne2935283:0
586 crwdns2915208:0crwdne2915208:0
University of Maine, Team 1-1, Diaz Fall 2014 crwdns2935289:0University of Maine, Team 1-1, Diaz Fall 2014crwdne2935289:0
UMAINE-DIAZ-F14S1G1
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
Bernd Dreyer - crwdns2934203:0crwdne2934203:0
I need more information for step 12: I removed the old roller. Unfortunately I don't know anymore how exactly the metal discs and the white plastic rings are placed.
Daniel Roller - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,554
