Samsung BD-F7500 Blu-ray Player Disc Reader Replacement
  1. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
  5. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Reader: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove spring on the side of the disc tray by carefully pulling it off its hook.
  6. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two black tabs, found at the end of the black bar across the disc tray. The tabs are located on the opposite side of the spring.
    • While simultaneously pushing both tabs in, lift up the black plastic bar.
    • Using a spudger, it is helpful to push in the tab as well as using the spudger as a lever.
    • The tabs are weak, constant pressure is the key, not overpowering force.
  7. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the ribbon cable, flip down the black bar located on the connector.
  8. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four (4) 10 mm screws using a phillips head #J1 screwdriver.
    • Remove the small metal bars by pulling it outwards.
    • The metal bars should have some wiggle room allowing it to be pulled out. It may be handy to push it up from underneath the disc tray.
  9. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
    • The laser may need to be turned on its side as its pulled out.
James McMicheal
crwdns2935283:009/28/17crwdne2935283:0
574 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G6, Crane Fall 2017 crwdns2935289:0Eastern Washington University, Team S2-G6, Crane Fall 2017crwdne2935289:0
EWU-CRANE-F17S2G6
crwdns2942667:0crwdne2942667:0 2,266
