Samsung BD-F5900 Main Logic Board Replacement
  1. Samsung BD-F5900 Main Logic Board Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Main Logic Board Replacement, Power Supply: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F5900 Main Logic Board Replacement, Power Supply: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
  6. Samsung BD-F5900 Main Logic Board Replacement, Main Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  7. Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the WiFi board cable connector
  8. Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung BD-F5900 Main Logic Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
Louis McKean
crwdns2935283:010/18/17crwdne2935283:0
528 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G21, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G21, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G21
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 561
