A device that fails to power on is not very useful. The Samsung BD-E5400 does not have a battery, so a possible source could be a damaged power cord. This guide will show you how to replace your power cord and restore your Samsung BD-E400 to its former glory!
Remove the two 10mm Phillips #1 screws.
Remove the one 8 mm Phillips #1 screw.
Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
Unplug the small wiring bundle attaching the body of the device to the cover.
Lay the cover aside.
Remove the two 8 mm long, #1 Phillips head screws.
Lift up the plastic component cover to remove and lay aside.
With the motherboard exposed, locate the point where the power cord is attached.
Separate the portion of the cord encased in the black grommet from the frame of the device.
Unplug the power cord from the motherboard.
