This guide tells you how to remove a faulty logic board and install a new one.
Push down on the back cover of the phone, then remove the back cover.
Remove the (4) 4.2 mm screws from the four corners of the battery slot.
Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
Remove the (3) newly uncovered 4.3 mm screws.
Remove the back outside casing using the plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect connecting cord using tweezers.
