Samsung Alias 2 Hinge Replacement
  1. Samsung Alias 2 Hinge Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the back cover of the phone and remove it.
  2. Samsung Alias 2 Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the battery from the device.
  3. Samsung Alias 2 Hinge Replacement, Hinge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws on screen.
  4. Samsung Alias 2 Hinge Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to remove the front outside casing.
  5. Samsung Alias 2 Hinge Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove ribbon connector next to camera using tweezers.
  6. Samsung Alias 2 Hinge Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the two 3.95 mm screws underneath that ribbon connector.
    • Be careful not to lose their accompanying plastic washers.
  7. Samsung Alias 2 Hinge Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the two halves of the phone apart.
    • The phone will not slide straight apart. You have to angle the back half up a little.
    • Do not force it. Jiggle it a little if it doesn't come apart.
  8. Samsung Alias 2 Hinge Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic panel cover from the hinge.
  9. Samsung Alias 2 Hinge Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.41 mm screw out from underneath plastic cover.
  10. Samsung Alias 2 Hinge Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop out the top half of the hinge with the plastic opening tool. This will release the hinge cover for removal.
  11. Samsung Alias 2 Hinge Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off the hinge cover.
  12. Samsung Alias 2 Hinge Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Alias 2 Hinge Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.71 mm screws on the hinge using screwdriver.
    • Under these screws will be a washer, spring, and small metal disc. Make sure you don't lose these.
  13. Samsung Alias 2 Hinge Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Verizon logo from the back of phone using the plastic opening tool.
    • The logo is attached with glue. It will be sticky, but it just pulls off.
  14. Samsung Alias 2 Hinge Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.44 mm screws from the back.
    • Remove the three 4.35mm screws from under the Verizon logo.
    • Make sure you don't mix the screws together.
  15. Samsung Alias 2 Hinge Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back off by using the plastic opening tool.
    • Do not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
  16. Samsung Alias 2 Hinge Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the yellow tab.
  17. Samsung Alias 2 Hinge Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the connecting cord using tweezers.
  18. Samsung Alias 2 Hinge Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rectangular ribbon.
  19. Samsung Alias 2 Hinge Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board.
  20. Samsung Alias 2 Hinge Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.95 mm screws.
    • The two rightmost screws must be pulled out with tweezers after unscrewed.
  21. Samsung Alias 2 Hinge Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the hinge out.
Chris
crwdns2935283:004/16/11crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-35, Maness Spring 2011 crwdns2935289:0Cal Poly, Team 12-35, Maness Spring 2011crwdne2935289:0
CPSU-MANESS-S11S12G35
crwdns2942667:0crwdne2942667:0 4,421
