If the main display on your phone is cracked, depicting a frozen image, or not displaying an image at all, then installing a new display may fix these problems.
To remove the back casing, firmly press down and push towards the bottom of the phone.
With the casing removed, lift the battery from the indicated indentation.
From here, you can now access the SIM card and model/serial numbers.
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
Your casing should be separated and the three loose buttons put to the side.
Slowly remove the back casing by gently pulling the ribbon connection.
Gently pull on the wires to remove the front casing.
Your front casing and front speaker are now released.
Locate the display screen.
Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
Slide the spudger across the bottom of the display and slowly push up.
Slowly pry the spudger up to remove the display.
To remove the casing as a whole, slowly lift up and towards the right side of the phone.
