Samsung ATIV Smart PC 500T Front-Facing Camera Replacement
  1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the front-facing camera with your forefinger.
    • Grip the camera with your thumb and forefinger and lift up to remove the camera from the socket at its base.
Crystal Dinh
crwdns2935283:009/23/15crwdne2935283:0
1,062 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-6, Williams Fall 2015 crwdns2935289:0Baylor, Team 6-6, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S6G6
crwdns2942667:0crwdne2942667:0 1,641
