Samsung ASV09PSBAN Circuit Board Replacement
  1. Samsung ASV09PSBAN Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the power from the circuit breaker.
  2. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the front grille panel by placing your hands at the top of the air intake cover.
  3. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to remove the air filters.
    • Clean the air intake screen with a vacuum if necessary.
  4. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw from the small panel on the right side.
    • Remove the cover.
  5. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black wire from the unit.
  6. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two parts of the white wire.
  7. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws from each side of the front panel.
  8. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Completely remove the front panel.
    • If you can not remove it easily, use a spudger to carefully pry it open.
  9. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old circuit board from the three notches holding it in place.
    • Thread the bundled white wire through the slot and remove the circuit board completely from the unit.
    • Install a new circuit board.
  10. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinstall the front panel.
    • Replace the two screws on each side of the front panel.
  11. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the white wires.
    • Thread the black wire through the slots.
  12. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the small cover.
  13. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinstall the filter.
  14. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Restore the power to check if the unit is functioning.
  15. Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ASV09PSBAN Circuit Board Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the unit is functioning, turn the fan off, and reinstall the front grille panel.
    • At the end, you can turn it on again.
Jenny
crwdns2935283:003/22/21crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G12, Sinclaire Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G12, Sinclaire Spring 2021crwdne2935289:0
UMASSD-SINCLAIRE-S21S1G12
I am having problem like different way, if I set temperature from 23'C to 17'C than only outdoor unit (compressor unit) start working. Even though it's started, but I feel the temperature like 29 'C only. What will be the problem? Suggest me..
Kishore Kumar S - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 3,255
