Samsung A7 (2018) SM-A750FN Display Replacement
  1. Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove SIM tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device off and remove the SIM tray.
  2. Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove backcover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove backcover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove backcover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a heat gun, heat the back of the device to loosen the adhesive securing the back cover.
    • Use a suction cup to lift the abck cover from the frame and insert a pick or plastic tool in between to pry the cover loose.
    • Work around the whole back cover to separate the back cover and frame.
    • If the adhesive is hard to remove, heat the area up again to loosen it.
    • The back cover is glass, so care is needed that it doesn't break.
  3. Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove mid-frame: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Remove mid-frame: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7 screws on the upper half of the frame.
    • Remove the 8 screws on the lower half of the frame.
    • The frame can now be removed by pushing it away from the screen. It is held in place by little clips.
    • If the screen does not come lose, insert a plastic pick or spudger to release the frame.
  4. Samsung A7 (2018) SM-A750FN  Display  Replacement, Disconnect battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Disconnect battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Disconnect battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery.
    • Remove the black plastic cover from the daughter board
    • On the left side of the daughter board is another small board. This can either be pried loose and removed or the cable can be disconnected.
  5. Samsung A7 (2018) SM-A750FN  Display  Replacement, Mainboard removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Mainboard removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 2 cables; the left is for the Display the right connects the mainboard and daughter board.
    • Remove the mainboard screw.
    • The camera can remain connected to the mainboard as it can be removed as one piece.
    • Remove the right cable from the daughter board below.
  6. Samsung A7 (2018) SM-A750FN  Display  Replacement, Display removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Display removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung A7 (2018) SM-A750FN  Display  Replacement, Display removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a heat gun to heat up the front of the display.
    • Insert a thin tooll between the glass and the frame to create a small gap.
    • Insert a plastic tool and work around the edge of the glass to separate the display from the frame.
    • The LCD is also glued, so it is difficult to remove the glass without breaking the LCD. For this guide, replacement of the glass and LCD was conducted.
    • Once the screen has been removed, remove any excess adhesive from the frame.
    • Insert the display cable through the hole. Connect it to the mainboard and test it before glueing it to the frame.
    • To reassemble, complete the same steps in reverse.
crwdns2935229:08crwdne2935229:0
Harvey
crwdns2935283:002/15/16crwdne2935283:0
6,051 crwdns2915208:0crwdne2915208:0
Your comment is too short. Please write something over 12 characters. It is currently 9 characters.
Qasim Abdi rashiid - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 6,972
