Samsung 500C ChromeBook CPU Fan Replacement
  1. Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven screws from the back panel of the device using a Phillips #0 screwdriver.
    • Four of the screws are under the rubber feet so they will need to be removed with a spudger.
    • Remove the back panel from the laptop.
  2. Samsung 500C ChromeBook CPU Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung 500C ChromeBook CPU Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung 500C ChromeBook CPU Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two screws holding in the CPU fan.
    • Lift the CPU fan.
    • You might encounter some slight resistance from the thermal paste on the heatsink.
    • Detach the cord attached to the fan and attach it to the new CPU fan.
    • Insert the new fan and reassemble the device.
Enjoy your cool laptop!
Garrett Kissinger
crwdns2935283:002/24/14crwdne2935283:0
704 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-2, Lauer Spring 2014 crwdns2935289:0Michigan Tech, Team 1-2, Lauer Spring 2014crwdne2935289:0
MTU-LAUER-S14S1G2
la pantalla no enciende, el ventilador arranca pero se apaga, el boton de poder da señal de encendido pero no enciende la pantalla
sergio rafael aguilar cantoral - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,052
