Samsung 500C ChromeBook Battery Replacement
  1. Samsung 500C ChromeBook Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung 500C ChromeBook Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung 500C ChromeBook Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung 500C ChromeBook Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Garrett Kissinger
crwdns2935283:002/24/14crwdne2935283:0
704 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-2, Lauer Spring 2014 crwdns2935289:0Michigan Tech, Team 1-2, Lauer Spring 2014crwdne2935289:0
MTU-LAUER-S14S1G2
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - crwdns2934203:0crwdne2934203:0
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 3,307
