Samsung 27E510C NAV Button Replacement
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung 27E510C  NAV Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung 27E510C  NAV Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung 27E510C  NAV Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung 27E510C  NAV Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung 27E510C  NAV Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung 27E510C  NAV Button Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
giggythore
crwdns2935283:010/14/17crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 783
