Salter Brecknell Model 311 Disassembly
  1. Salter Brecknell Model 311 Disassembly, Prepare to disassemble: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Salter Brecknell Model 311 Disassembly, Prepare to disassemble: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the scale over, remove batteries.
    • It requires 4 AA batteries and has two plastic clips to hold the upper batteries.
    • Be careful not to break the plastic clips.
  2. Salter Brecknell Model 311 Disassembly, Remove primary set of screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws at 1 o'clock and 7 o'clock positions, using the mini screwdriver.
    • Be careful with the mini screwdriver to refrain from stripping the head of the screw.
  3. Salter Brecknell Model 311 Disassembly, Remove secondary set of screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws at 5 o'clock and 11 o'clock positions, using the mini screwdriver.
    • Unscrew them slowly, keeping the tool directly perpendicular to the surface to avoid damage, as they are self-tapping.
  4. Salter Brecknell Model 311 Disassembly, Remove aesthetic top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Salter Brecknell Model 311 Disassembly, Remove aesthetic top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the weighing platform by unscrewing carefully.
    • Rotate it about 60 degrees so that it can be lifted vertically.
  5. Salter Brecknell Model 311 Disassembly, Split Open Plastic Shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently tap the side of the upper plastic half, be careful as it can be snapped easily.
    • There are two clips that attach the upper half to the bottom half.
    • Be careful to avoid breaking the clips off.
  6. Salter Brecknell Model 311 Disassembly, Remove Central Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two central screws, connecting the scale weight.
    • The tightness of the screws can affect the scale's accuracy, so it is important to take note of this.
  7. Salter Brecknell Model 311 Disassembly, Separate the Plastic Shell: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top half of the plastic shell to the side. Be careful, as the electrical circuit board will connect both parts.
    • The wires are exceptionally thin, be careful to not rip them.
  8. Salter Brecknell Model 311 Disassembly, Inspect the wiring: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Salter Brecknell Model 311 Disassembly, Inspect the wiring: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check for wiring issues connecting to components; look for torn cables.
    • Look for loose wires or connections. Every single wire should be fully attached at both ends.
  9. Salter Brecknell Model 311 Disassembly, Inspect the circuit board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check back and front of circuit board for liquid damage.
    • Sometimes you can see damage from the back, but if you inspect the front side, it should be very obvious.
    • If brown stains are visible on the board, there is likely liquid damage on the board.
    • If you find liquid damage, unscrew the mini screws, and replace the board.
    • You will need to re-solder the electrical cables if you replace the board.
  10. Salter Brecknell Model 311 Disassembly, Important Reassembly Actions: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble by inverting steps 1 - 7.
    • Remember to only torque the central screws till they will not back out, not more.
Steven
crwdns2935283:006/22/23crwdne2935283:0
191 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 172
