Saitek X52 Pro Disassembly
  1. Saitek X52 Pro Disassembly, Get your tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  2. Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Please take a moment and note how your joystick is assembled and all the parts that can be dettached. I recommend taking a few photos before dismantling it.
    • With the Phillips screwdrive unscrew the #1 to #4 screws in Fig. 1.
    • Using the Torx T10 head, unscrew the #5 (Fig. 1), #6, #7 and #8 screws (Fig. 2)
    • Screws 5 & 6 have a larger thread pace than 7 & 8, although the heads are the same. So please take care when you screw them back on (Fig. 3).
    • Using your hand, unscrew #9 (Fig. 2). Please note that you cannot completely remove this screw, but you don't need to do this anyway.
  3. Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the plastic bracket and the support holding the "Pinkie trigger" by pushing it towards the trigger (Fig. 4).
    • DO NOT force its removal, or you can break it.
    • Be careful not to break the Pinkie trigger wire!
    • Remove the stick cover that will expose the contacts and wiring (Fig. 5)
  4. Saitek X52 Pro Disassembly, Fixing it: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the small metal plate.
    • Bend it just a little from the middle so that pushing the trigger actually pushes the small blue switch inside the stick.
    • Test the trigger before putting back the plastic cover
    • Remember when screwing the screws that 5&6 go to the bottom sides and 7&8 go at the top.
    • Note: Inside the trigger there is two screws which can be used instead of either extend or retract the pin that presses the metal plate. Try adjusting this first.
crwdns2935229:022crwdne2935229:0
Cri Cri
crwdns2935283:001/22/14crwdne2935283:0
632 crwdns2915208:0crwdne2915208:0
crwdns2947412:025crwdne2947412:0
Amazing this is what I was exactly looking for!! My trigger stopped work but only heard a single click. Once i opened it up one of the contacts was stuck down. A little adjustment and once again it was working. Getting the hand guard off was very tricky. I did damage the cable guide thing for the pinky switch but it still works. Thank you soo much!!!
Mathew Smith - crwdns2934203:0crwdne2934203:0
Glad it helped you! It appears to be a common fault with this joystick.
Sorry to hear about the damaging cable, but I imagine is fixable if it breaks over time.
Cri Cri - crwdns2934203:0crwdne2934203:0
Fixed it!! Thank you so much for this guide! I ended up over bending it and then tried to straighten it out again and then it shot off somewhere, but luckily the piece fits back in and then i tweaked it until it worked! -Nate
nenglish87 - crwdns2934203:0crwdne2934203:0
This helped a great deal! The Thumb POV had a screw that dropped out and prevented it from going left. By using this I found out why it wasn't working by disassembling it and solved my problem. Thanks!
Arthur Moyer - crwdns2934203:0crwdne2934203:0
I was kind of hoping this would be a full Disassembly, as i have much more intricate problem with mine.
Paul - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 227
crwdns2942667:0crwdne2942667:0 29,889
