Saitek Cyborg V3 Disassembly
  1. Saitek Cyborg V3 Disassembly, Open the mouse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saitek Cyborg V3 Disassembly, Open the mouse: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saitek Cyborg V3 Disassembly, Open the mouse: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screw driver to open the back cover.
    • Gently push away the bottom part on the opposite side to the cable.
    • As in the "push away" step, there should be about 30° between the bottom and top part. Push on the bottom part up, so the fit is tight around the cable. Slowly move parts together to reduce the angle.
  2. Saitek Cyborg V3 Disassembly, Dismantle the big top cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saitek Cyborg V3 Disassembly, Dismantle the big top cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to unscrew the big top mouse part with both buttons.
    • Use whatever you find appropriate (I used a screwdriver) to gently push the clips (yellow) and next push to one of the circles (red) to separate the big top part.
  3. Saitek Cyborg V3 Disassembly, Dismantle cover with DPI button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saitek Cyborg V3 Disassembly, Dismantle cover with DPI button: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use whatever you find appropriate (I used a screwdriver) to gently push the clips (red) and use whatever you find appropriate (I used a thin screwdriver bit) to push the pin (yellow).
    • Now if you very gently push to the bottom part of the cover, it should pop out on itself.
  4. Saitek Cyborg V3 Disassembly, Separate the electronics: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 bit to unscrew two screws on the motherboard.
    • Carefully lift the whole motherboard out of the mouse.
Vaclav Sobotka
crwdns2935283:001/24/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 397
