Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
Inside is a feather and a small glass ball. Store carefully.
With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
The new sealing ring is already waiting, but first it has to be cleaned properly.
Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
Three screws hold the brew groups together, loosen.
The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
Make sure you put this part back into the base of the piston when you reassemble it. It sits near the base of the brew group
Since the lever is gone you can easily pull out the piston. It has no seal.
Do you have some recomendation how to do it (change an o-ring situated under brewing chamber unit)? I cannot find any solution for that.
There is a cover over the o-ring which is glued in and must be carefully removed (sometimes it breaks…). Later it must be attached again with special glue. I prefer to replace the brewing chamber with a new (or used) one.
VauWeh -
That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
Repeat the steps in order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:05crwdne2947412:0
How does the metal bar you see in figure 7 get put back in place when you reassemble the unit?
Not easy to describe. First try to use the brewing unit without the metal, maybe that's already enough. Or try borrowing another unit to compare.
i dismantled only the square part to clean the metal filter. A 1mm seal fell out of no where and wasnt sure where to put it back. I placed it back into that L shape piece on top of it and now there is some coffe leaking into the square piece. Please help. I have the diagram to show the exact piece i mentioned but how do i show it here?
I suppose it is the seal visible in Saeco Brühgruppe zerlegen, step 1, picture 3. Be sure to put in the little ball, the spring and the seal, before you tighten the screws on the L-shaped hose. There is another gasket on the axis in step 2, picture 1, perhaps you removed it?
VauWeh -
Once I saw someone put the L-shaped hose in the wrong way. The exit must point into the machine.
VauWeh -
When putting back the spring and glass ball note that the narrow end of the spring points down
Colin Macdonald - crwdns2934203:0crwdne2934203:0
Was soll man tun, wenn die Brühgruppe festgelaufen ist und keine Bewegung möglich ist? Mit anderen Worten: wie kann ich diese ausbauen?
Robert de Kok - crwdns2934203:0crwdne2934203:0
In Schritt 4, Bild 1 ist zu sehen, wie die Torx T10 Schraube am Zulauf (mit etwas Glück) gelöst werden kann. Wenn das möglich ist, kann die Brühgruppe mit etwas Gewalt herausgezogen werden, der Zulauf löst sich und bleibt in der Maschine stecken. Eine andere Möglichkeit ist eventuell, den Saeco-Testmodus (Google hilft) einzuschalten und die Brühgruppe in Ruheposition zu bewegen. Viel Glück!
VauWeh -
when the brewing unit got stuck, what to do in order to take it out?
Die Glaskugel ist bei der Demontage rausgefallen und ich habe nicht gesehen, wo genau die war. Kommt die auf die breite Seite der Feder, also nach oben?
user123 - crwdns2934203:0crwdne2934203:0
Zuerst kommt die Kugel in den Kolben rein. Dann die Feder mit der spitzen Seite zur Kugel, damit die gut festgehalten wird. Dann den Auslauf drüber, Dichtung nicht vergessen.
Funktion: Der Kaffee wird von unten her an der Kugel vorbei gedrückt. Die fängt dann an zu vibrieren und erzeugt dadurch den Schaum für die Crema.
VauWeh -
