When the body on the steam valve is cracked, it has to be replaced. This will show how to do that.
Remove all attachments such as drawers, water tank, brewing unit.
Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
The bean container is fixed with two Phillipps screws. Unscrew those.
Lift the bean container up und remove it from the device.
Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
The steam valve is located on the top right of the machine. If it has cracks, water will drip out of the valve body.
Remove the clamp securing the pressure hose to the valve body.
Disconnect the pressure hose from the valve body.
The microswitch is mounted on the underside of the gray frame with two notches. Insert a small screwdriver into the gap under the gray frame. Gently push the two notches one after the other and lift the microswitch upwards. The cables can stay connected.
The steam valve is still secured with a catch. Lift the catch with a flat-head screwdriver and slide the complete valve to the right.
To remove the valve it can now be pulled out of the gray frame in a forward direction.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
