Remove all attachments such as the water tank, brewing unit, bean compartment lid, and drip tray. Remove all coffee beans.
Turn the machine over so that the back is facing you. Remove the two Torx T10 screws at the bottom. Pull the back out slightly at the bottom and lift it down.
Important components are immediately visible:
The main circuit board
The pump
The flow meter
The boiler
Unscrew the Torx T10 screw on the finger guard in the coffee bean compartment.
Lift out the finger guard.
Unscrew the three Torx T10 screws in the coffee bean compartment.
Lift the upper cover slightly at the rear edge.
Then lift the cover completely off.
When reassembling, make sure that the grinder adjustment is correctly positioned.
Figure 3 shows the grinding mechanism, which can now easily be removed.
Unscrew the two Torx T10 screws at the bottom of the front.
Slide the right side panel back slightly and remove it.
Slide the left side panel back slightly and remove it.
Hier weitere wichtige Bauteile:
The boiler
Valve block, consisting of four solenoid valves
Grinder
Drive
To be on the safe side, remove the three black cables of the flowmeter from their holder so that the pump has a free path.
Pull the two flat connectors off the pump.
The thermal fuse on the cable is glued to the pump at the factory. Carefully scrape off the adhesive and pull the thermal fuse out downwards.
The rubber holder for the pump is hooked at the top. Push the rubber hook away from you with a metal spatula and leave the metal spatula in place.
Take a strong screwdriver and now push the bracket with a lot of force towards the water tank side until it gradually comes out together with the pump.
Lift out the pump. It is still connected with two hoses.
Pull the pump out of the lower water connection.
Insert a 12 mm open-end wrench into the upper pump outlet.
Turn the black connection slightly counterclockwise until it comes loose.
Turn the pump all the way out.
The factory-installed pump was an Ulka EP5FMGW. Replace it with an Ulka EX5, which has a metal fitting.
Secure the thermal fuse to the pump with electrical tape.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0VauWehcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
