Saeco Magic Cappuccino SIN017 Opening
  1. Saeco Magic Cappuccino SIN017 Opening, Opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Magic Cappuccino SIN017 Opening, Opening procedure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Never forget: Disconnect the power plug before starting repairs!
    • You can find the model designation SIN017 on the bottom of the machine.
    • Pull off the steam valve knob. To do this, you must pull hard.
    • Remove all attachments, i.e. the water tank and the drip tray.
    • Pull off the Cappucinatore.
  2. Saeco Magic Cappuccino SIN017 Opening: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Magic Cappuccino SIN017 Opening: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Magic Cappuccino SIN017 Opening: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two Phillips screws on the back.
    • Lay the machine on its side. Unscrew the two Phillips screws at the front of the underside.
    • Lift off the top cover and set it aside.
    • Do not remove the cover completely. It is connected with many cables. You may be able to disconnect the yellow-green cable from the hot plate, then you have more room to move.
  3. Saeco Magic Cappuccino SIN017 Opening: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is a view into the opened machine. The components are clearly visible:
    • Pump
    • Boiler with thermal switches
    • Steam valve
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289,185 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 2,024
