Saab 9-5 97-2010 Turbo Replacement
  1. Saab 9-5 97-2010 Turbo Replacement, Final Checks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have refitted your Turbo and reconnected all hoses and filters you need to check a few things:
    • Check the oil level - this will certainly need topping up. Bear in mind that you will need to replace the oil and filter within 500 miles.
    • Ensure your coolant and all other fluids are topped off to ensure they will not cause any problems in general operation.
    • Run the motor
    • Pay close attention to coolant levels and any warning on the instrument cluster
    • There may still be oil in the exhaust system, this will start to burn as the vehicle warms up.
    • If you notice smoke immediately (from a cold engine) stop the motor immediately and check all your connections. This could be an indication that oil is getting burnt in the turbo.
    • If all looks ok and the car is brought up to temperature, while idling, gently increase the revs up and down over the course of a few minutes - shut down and check for leaks. You are done!
Andrew Armstrong
crwdns2935283:005/23/18crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 964
