SRM Power Meter Battery Replacement
  1. SRM Power Meter Battery Replacement, Open the Power Meter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Open the Power Meter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Open the Power Meter: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the chain rings. On some models there are little screws to open the cap. On my FSA Model there is a tab to pop open the cap.
    • Make sure the seals stay intact.
    • There are 2 batteries glued in. They are connected with a power cable that has a little 2 pin plug.
  2. SRM Power Meter Battery Replacement, Remove Batteries: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Remove Batteries: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Remove Batteries: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • ATTENTION: Make sure you don't damage the thin cooper wires marked in yellow.
    • Unplug the batteries from the circuit board. (red)
    • With the solder gun remove the cables from the old batteries. Make sure not to melt the cables or plug.
  3. SRM Power Meter Battery Replacement, Prepare new Batteries: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Prepare new Batteries: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Prepare new Batteries: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • My batteries had mounting pins attached to the silver side. They have to be remove with pliers.
    • The terminal pins have to be bent straight.
    • Finally the pins have to be cut to the same length as the old batteries.
  4. SRM Power Meter Battery Replacement, Attach Wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Attach Wires: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Attach Wires: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Add heat shrink to cables and solder them to battery. Red to (+) and black to (-)
    • Push the heat shrink up to cover the entire pin and soldering connection.
    • Twist the wired back together gently.
  5. SRM Power Meter Battery Replacement, Insert the Batteries: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Insert the Batteries: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SRM Power Meter Battery Replacement, Insert the Batteries: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the new batteries. There is a + on the circuit board on the side where the red wire goes.
    • Push the batteries gently back into place.
    • Connect the power meter and check the battery status of the sensor. On my Garmin I see NEW.
midiman127
crwdns2935283:004/27/10crwdne2935283:0
914 crwdns2915208:0crwdne2915208:0
Super Anleitung, vielen Dank!
Hast Du das Powermeter mit einem Garmin Gerät verbunden? Wird dir da der Batteriezustand angezeigt? Ich habe mir ein gebrauchtes PM 7 gekauft, aber er zeigt nur „- - -„ an. Jetzt weiß ich leider nicht ob sich ein Wechsel schon lohnt
Felix - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 15,599
