If your device has completely stopped working you may need to swap out the motherboard inside your device. In this guide you will open up the boombox following the prerequisite disassembly guide and then replacing the motherboard with a working version.
            Lift up the handle to reveal the screws.
            Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
            Flip your device over.
            Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
            Flip your device back over to access the top of the device.
            Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
            Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
            Lift off the top, beginning from the back of the device.
            Disconnect the CD drive ribbon cable from the top of the device.
            Disconnect the remaining cables from the motherboard.
            Once you have removed the top, we will begin removing the front of the device.
            Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
            Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
            Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
            Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
            Firmly pull off the front of device.
            Gently pull the corresponding cables individually from the top of the motherboard to remove them.
            For the next 3 steps, use the plastic prying tool if needed.
            Remove the following 2 cables from the left side of the board.
            Remove the final cable on the bottom right side of the motherboard.
            Remove the five 1/2inch screws from the motherboard using a Phillips #2 screwdriver.
            Gently lift the motherboard from its compartment
            Now you are done!
crwdns2935229:05crwdne2935229:0
Where i can buy this motherboard?
Got it apart plug came back on staying on stand bye,?
My boombox is showing demo only cannot switch off and change mode. After 2 seconds.
