Before attempting this guide, be sure you check out the device troubleshooting page to see if you can get your cd player working that way.
If not, we are going to go ahead and open the device as you will need to swap out your CD Drive for a working one.
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Flip your device over.
Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
Flip your device back over to access the top of the device.
Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
Lift off the top, beginning from the back of the device.
Disconnect the CD drive ribbon cable from the top of the device.
Disconnect the remaining cables from the motherboard.
Once you have removed the top, we will begin removing the front of the device.
Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
Firmly pull off the front of device.
Flip the top and locate the CD module on the right side.
Use a Phillips #2 screwdriver to unscrew the four 1/2 inch screws.
Firmly grab and lift the CD drive from its plastic compartment to remove it.
We're can I buy or order the new drive? And possibly a new top for the cd
