Before attempting this guide, be sure you check out the device troubleshooting page to see if you can get your bluetooth working that way.
If not, we are going to go ahead and open the device as you will need to swap out your bluetooth module for a working one.
            Lift up the handle to reveal the screws.
            Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
            Flip your device over.
            Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
            Flip your device back over to access the top of the device.
            Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
            Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
            Lift off the top, beginning from the back of the device.
            Disconnect the CD drive ribbon cable from the top of the device.
            Disconnect the remaining cables from the motherboard.
            Once you have removed the top, we will begin removing the front of the device.
            Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
            Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
            Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
            Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
            Firmly pull off the front of device.
            Lift the plastic tab on the ribbon cable on the bluetooth module using the spudger.
            Pull the ribbon cable out to remove it.
            Use a Phillips #0 screwdriver to unscrew the single 1/4 inch screw.
            Gently grab the top and lift the chip up to remove it.
Where did you get the Bluetooth module?
Great fix it article. Thank you. I, too am wondering where to get the replacement Bluetooth module? Part number as well. Thank you very much.
