This guide will allow you to detach the faceplate in order to replace existing buttons or screen on your Sony Ericsson W890i
Flick the two lock tabs into the unlocked positions by pushing each button forward.
Pop the back cover up using the groove on the top of the phone.
You can now access the phone's battery.
Using a spudger, remove the battery and set it aside.
Remove the two small rubber pieces that cover the lower screws.
Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
Gently pry off the faceplate using a plastic opening tool.
Insert the plastic opening tool into the middle of the front and back panels of the phone.
Separate the front and back panels that were pryed open with the plastic opening tool.
