SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement
  1. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement, How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the covering cap. (pg. 23)
  2. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the unit upside down on a non-slip surface and remove the six screws. (pg. 23)
  3. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower part of the housing with a swiveling motion away to the side. Note the SOMNOcomfort series uses a shorter circuit board than the balance series ventilator. (pg. 23)
  4. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connector (X1) from the circuit board.
    • Pull the connecting cable (64) from its mount.
    • Now set aside the lower part of the housing. (pg. 23)
  5. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, how to close the compartment and reverse the process.
    • Hold the lower part of the housing to the upper part at an angle
    • Attach the connector (X1) to the main circuit board. When doing so the connector’s nub has to point towards the lock. (pg. 24)
  6. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Properly align the main circuit board inside the unit.
    • Attach the connecting cable (64) to its mount (pg. 24)
  7. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the lower part of the housing on the upper part (47). Please make sure the main circuit board (44) is aligned properly, and that the connecting cable (64) is not being squeezed anywhere. (pg. 24)
  8. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now reattach the upper part of the housing by tightening the six screws. (pg. 24)
  9. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the covering cap. (pg. 24)
  10. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement, Fuse: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the unit (refer to the guide "How to Open and Close Housing")
  11. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the defective fuse(76 or 77) and replace with a new one. (pg. 27)
    • Ensure the correct amperage is used. Use fuses mentioned in the Replacement parts list only. Using other fuses may cause damage to the main circuit board.
    • 76 refers to the fuse in SOMNObalance. 77 refers to the fuse in SOMNOcomfort.
  12. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the Unit (refer to the guide "How to Open and Close Housing").
Check that everything is working properly after having successfully replaced the fuse.
Katie Steidl
crwdns2935283:005/04/20crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G3, Zimmerman Spring 2020 crwdns2935289:0Cal Poly, Team S1-G3, Zimmerman Spring 2020crwdne2935289:0
CPSU-ZIMMERMAN-S20S1G3
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 253
