SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement
  1. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lid from the pot of the SILVERCREST Monsieur Cuisine Connect before processing
    • The instructions are identical for both sides.
    • Place the pot on the work surface with the opening facing down
    • Open and remove the screw cap
  2. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips head screw
  3. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lower part is fixed, pay close attention to the order of removal.
    • Remove the cover by first pulling on the top edge.
    • Then turn the cover to the right or left out of the fixation
  4. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The springs can look different depending on their condition. Sometimes they may not even be present. Note that all spring leftover parts must be removed.
    • Place the cover with the open side up in front of you
    • Remove the first spring with a suitable tool
  5. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the second spring with a pair of needle nose pliers.
  6. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new matching spring.
    • A 25mm (1inch) spring is recommended.
    • Most springs are too long. Shorten them using a pair of pliers.
  7. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the second smaller spring with the Phillips head screw
    • The correct size of this spring is vital!. The lock must be completely withdrawn in normal condition.
    • Recommendation here is a 5mm spring
  8. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the other end of the spring to the movable part of the locking mechanism
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Alex
crwdns2935283:012/31/20crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Vielen Dank! ? Monsi lebt wieder. ??
Vanessa Meinold - crwdns2934203:0crwdne2934203:0
Super das es funktioniert hat!
Alex -
Wo bekomme ich diese Zugfedern und welche Größe benötige ich genau? Vielen Dank schon einmal
kathrin schulte - crwdns2934203:0crwdne2934203:0
Entweder bestellst du sie online oder du versuchst es in einem Fachhandel. Der Ersteller dieser Anleitung gibt die Längen der Federn mit 5 mm und mit 25 mm an. Wenn du nur längere findest, kannst du sie theoretisch auch selbst kürzen.
Fabian Neidhardt -
Ich habe die Zugfedern in diesem Artikel mit einem Link hinterlegt. Diese müssen zum Teil mit einer Zange manuell gekürzt werden. Das ist aber relativ einfach möglich.
Alex -
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 190
crwdns2942667:0crwdne2942667:0 15,749
