SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement
  1. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement, Tension Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, pull the armrest upwards to remove it from the chair.
    • Hold both ends of the arm pad to ensure a secure grip before pulling with moderate force.
    • This will work best when the armrest is set at the highest adjustment.
  2. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the armrest upside down on a table.
    • Use an Allen wrench to remove the two 5 mm hex screws by turning counterclockwise.
    • Remove the arm shaft from the arm pad.
  3. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 2 mm Phillips screws securing the parts of the adjustment mechanism.
    • Be careful when removing the screws here. Some parts may slip down from underneath as parts loosen.
  4. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide the components of the adjustment track out, starting with the hard plastic parts.
  5. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay out everything for easy access, including the replacement spring.
    • Taking the two clasps, choose the one with the bar in the middle.
  6. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the adjustment tab up and insert the clasp piece into the arm shaft from the bottom.
    • Make sure you insert the slightly wider end first.
    • Check to make sure it rests neatly inside.
  7. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the T-shaped metal bar and insert it from the top.
    • Check to make sure it sits in the mold of the clasp.
  8. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the other clasp and insert it into the arm shaft from the bottom.
    • Push the adjustment tab up to ensure a smoother entry.
    • Check to make sure it rests neatly inside with the other parts.
  9. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loop one end of the 3 mm x 10 mm hook tension spring to the plastic hook of the clasp first.
    • Loop the other end of the spring to the hook on the T-shaped metal bar.
  10. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move to the chair and carefully push the arm shaft back in.
    • While pushing, make sure everything is leveled to avoid parts getting stuck in the process.
  11. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Phillips #1 screwdriver, secure the two 2 mm screws to the adjustment track.
    • Rotate the screwdriver clockwise to tighten the screws.
  12. SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SIHOO M57 Ergonomic Office Chair Armrest Tension Spring Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the arm pad back on.
    • Screw the two 5 mm hex screws back in place using an Allen wrench, rotating clockwise.
By the end of this guide, the armrest should be repaired and ready for use again.
Yifan Zhong
crwdns2935283:005/12/25crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
UC Davis, Team 3-5, Whithaus Spring 2025 crwdns2935289:0UC Davis, Team 3-5, Whithaus Spring 2025crwdne2935289:0
UCD-WHITHAUS-S25S3G5
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 411
