This guide will be showing step-by-step instructions on how to get to and replace the motor of the airsoft gun.
Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip.
Slide the cover off.
Pull the motor out from the inside of the hand grip.
Using a soldering iron and desoldering wick, desolder the wires from the motor.
Using a soldering iron, solder the wires onto the new motor.
