SG 552-1 Commando Barrel Replacement
  1. SG 552-1 Commando Barrel Replacement, Barrel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement, Barrel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SG 552-1 Commando Barrel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the remaining pieces of on the ends of the barrel.
Laura Schulz
crwdns2935283:010/05/12crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-41, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 18-41, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S18G41
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,719
