SENNHEISER GSP 500 Gaming Headset Disassembly
  1. SENNHEISER GSP 500 Gaming Headset Disassembly, Remove Right Cover Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove right Cover Plate (see attached PDF on how to remove).
    At the bottom of the page section called “Attached Documents”
    hectorhmoreno -
  2. SENNHEISER GSP 500 Gaming Headset Disassembly, Remove Right Ear Pad & Screw Covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove right ear pad by pulling outward. See attached PDF on how to remove.
    • Remove 5 screw covers with a toothpick.
    • Remove 5 screws with #1 Philips screw driver.
  3. SENNHEISER GSP 500 Gaming Headset Disassembly, Detach Volume Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SENNHEISER GSP 500 Gaming Headset Disassembly, Detach Volume Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove right speaker. But be careful with speaker cable as it is not very long.
    • Set volume knob all the way to 0% muted. Should fell a click by turning all the way counter-clockwise.
    • Remove 3 #00 Philips screws on circuit board.
    • Volume circuit board should come off. Some of the glue might hold it in, un-stick the glue with a very small flat head screw driver by prying it off the plastic housing.
  4. SENNHEISER GSP 500 Gaming Headset Disassembly, Fix Sound Cutting Out Problem: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To fix the sound cutting out problem.
    • Solider R11 with a jumper wire and R12 with a jumper wire, as shown. This will bypass the mute switches that have failed. The volume knob will still work just won't completely mute the headphones anymore. Which is not a big deal since you can still mute in windows settings.
hectorhmoreno
crwdns2935283:001/15/12crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
I had the right speaker break loose inside the housing. Thankfully the wires didn't break. I was able to glue it back in place and it's working fine again. Thanks for the teardown guide. I wasn't sure how to get into it to fix it.
Dillon Sly - crwdns2934203:0crwdne2934203:0
Awesome! Glad you got them works again.
hectorhmoreno -
It worked perfectly, thank you.
Simón C. - crwdns2934203:0crwdne2934203:0
Such an easy fix for a really annoying problem. Thank you for creating this guide. Saved me from buying a new headset :)
Rubick - crwdns2934203:0crwdne2934203:0
Works for GSP 600 as well. Thank you, problem solved!
Pavlik - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 3,302
