Remove right Cover Plate (see attached PDF on how to remove).
Remove right ear pad by pulling outward. See attached PDF on how to remove.
Remove 5 screw covers with a toothpick.
Remove 5 screws with #1 Philips screw driver.
Remove right speaker. But be careful with speaker cable as it is not very long.
Set volume knob all the way to 0% muted. Should fell a click by turning all the way counter-clockwise.
Remove 3 #00 Philips screws on circuit board.
Volume circuit board should come off. Some of the glue might hold it in, un-stick the glue with a very small flat head screw driver by prying it off the plastic housing.
To fix the sound cutting out problem.
Solider R11 with a jumper wire and R12 with a jumper wire, as shown. This will bypass the mute switches that have failed. The volume knob will still work just won't completely mute the headphones anymore. Which is not a big deal since you can still mute in windows settings.
crwdns2935103:0crwdne2935103:0
crwdns2947412:05crwdne2947412:0
I had the right speaker break loose inside the housing. Thankfully the wires didn't break. I was able to glue it back in place and it's working fine again. Thanks for the teardown guide. I wasn't sure how to get into it to fix it.
Awesome! Glad you got them works again.
It worked perfectly, thank you.
Such an easy fix for a really annoying problem. Thank you for creating this guide. Saved me from buying a new headset :)
Works for GSP 600 as well. Thank you, problem solved!
Where is the PDF file?
riccardo - crwdns2934203:0crwdne2934203:0
At the bottom of the page section called “Attached Documents”
hectorhmoreno -
