SCUF Reflex Joystick Replacement
  1. SCUF Reflex Joystick Replacement, Remove the middle trim: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips.
    • Loosen the rest of the clips and take the middle trim out.
  2. SCUF Reflex Joystick Replacement, Remove L1 and R1: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SCUF Reflex Joystick Replacement, Remove L1 and R1: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SCUF Reflex Joystick Replacement, Remove L1 and R1: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a tool to pop the R1 and L1 buttons off of the controller.
  3. SCUF Reflex Joystick Replacement, Unscrew the grips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Unscrew the grips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the screw from the bottom of each grip.
  4. SCUF Reflex Joystick Replacement, Unscrew behind L1 and R1: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screws behind the L1 and R1 buttons.
  5. SCUF Reflex Joystick Replacement, Pull the joysticks off: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Pull the joysticks off: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the joysticks off of the controller.
  6. SCUF Reflex Joystick Replacement, Pull the scuff buttons off: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the scuff buttons off the back of the controller by sliding them down.
  7. SCUF Reflex Joystick Replacement, Remove the rear case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Remove the rear case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the prying tool down the edge of the rear casing of the controller to remove the rear case.
    • Be sure to deal with all the clips!
  8. SCUF Reflex Joystick Replacement, Slide the battery out: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Slide the battery out: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery out of the controller. It's grey and held in by a couple of wires, so be careful not to damage them.
  9. SCUF Reflex Joystick Replacement, Unplug the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery to finish removing the battery from the controller.
  10. SCUF Reflex Joystick Replacement, Take the battery bracket out: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Take the battery bracket out: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screw on the back of the controller to remove the battery bracket.
  11. SCUF Reflex Joystick Replacement, Desolder the ribbon cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement, Desolder the ribbon cables: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to desolder the ribbon cables on the motherboard.
  12. SCUF Reflex Joystick Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug these four cables from the motherboard.
  13. SCUF Reflex Joystick Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to desolder the black and red wires off of the motherboard.
  14. SCUF Reflex Joystick Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard and the battery bracket from the controller to expose the joystick component.
  15. SCUF Reflex Joystick Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    • Use the soldering iron and the desoldering pump to desolder the 14 connections for the component.
  16. SCUF Reflex Joystick Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the component from the motherboard.
  17. SCUF Reflex Joystick Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SCUF Reflex Joystick Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put the new component on the motherboard.
    • Use the soldering iron to connect the new component to the motherboard.
Tri Truong
crwdns2935283:002/13/23crwdne2935283:0
429 crwdns2915208:0crwdne2915208:0
Hi! Wich replacement component do you use?
Antonis Lambropoulos - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 172
crwdns2936753:030crwdne2936753:0 839
crwdns2942667:0crwdne2942667:0 11,847
