Operating your mower with a dull blade can be hard on your lawn, leaving the grass tattered or torn rather than cut. This will cause it to look yellow and restrict healthy growth. Also, a damaged blade can be a danger to the operator or nearby people.
Replacing the blade isn't difficult and is a task that anyone should be able to complete in 15-30 minutes. There are some things to keep in mind as you start this project though. You will be working with a sharp object (the blade), so using a pair of heavy-duty gloves, removing the battery, and carefully blocking the blade are important safety measures to keep in mind as you start your work.
Once you've completed the replacement, I recommend mowing your yard right away and experience the satisfaction of your crisply mowed lawn!
Firmly grasp the battery, depressing the battery release and slide the battery out.
Turn the mower upside down on a flat, stable surface.
Use an 8" to 10" block of 2x4 to prevent the blade from spinning counterclockwise.
Using a 15 mm socket wrench, remove the blade nut by turning it counterclockwise.
Remove the nut spacer and blade insulator.
Remove the blade.
Identify the alignment shapes on the blade hub.
Install the new blade on the hub using the alignment posts.
Replace the insulator, spacer, and nut.
Set the torque wrench to between 350-400lbs.
Tighten the blade nut with the torque wrench by rotating the wrench clockwise.
