Ryobi RS290G Bearing Cap Assembly Replacement
  1. Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a TR20 Torx security screwdriver, remove the four 6mm screws.
    • Make sure to hold the backing pad firmly to prevent spinning.
  2. Ryobi RS290G Bearing Cap Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the backing pad, carefully pull on the rubber brake to remove it from the housing assembly.
  3. Ryobi RS290G Bearing Cap Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a TR 20 Torx security screwdriver, remove the single 3mm screw in the center of the bearing cap assembly.
    • Make sure to use pliers or another tool to prevent the fan from spinning, and use a torque wrench or torque screwdriver as the screw is secured with Loctite (a compound to prevent it from loosening).
  4. Ryobi RS290G Bearing Cap Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bearing cap.
    • You may keep the spring washer and washer for reuse if they are not worn/damaged.
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
Daniel
crwdns2935283:009/17/19crwdne2935283:0
639 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G5, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G5, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 699
