Ryobi RJ1861V Motor Housing Replacement
  1. Ryobi RJ1861V Motor Housing Replacement, Saw Bar Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Housing Replacement, Assembly Bar Bearing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi RJ1861V Motor Housing Replacement, Motor Housing: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After following prerequisite guides to get to the presented step, remove motor assembly from back housing.
    • Motor Assembly will be greasy
    • Motor Assembly
    • Motor Assembly Housing
  12. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using pliers to grab onto the elongated aluminium exterior of the housing, begin to slowly wiggle the motor assembly housing until it comes loose.
  13. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach red wires from base of the back of the housing .
  14. Ryobi RJ1861V Motor Housing Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the wires have been detached it should be relatively easy to remove and replace the Motor Assembly Housing
Ryan Quinlivan
crwdns2935283:004/08/19crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 140
