Ryobi P501G Motor Replacement
  1. Ryobi P501G Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screws at the top face of the saw, on the green plastic surface covering.
  2. Ryobi P501G Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P501G Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the eight outer screws of the plastic green encasement. They are marked in red in the picture.
    • Using a T15 torx screwdriver, unscrew all the holes, taking care not to lose any!
    It is a T15 screwdriver, NOT T5.
    Some of the screws are in deep recesses. A 1/4” bit holder or bit holding screwdriver will not fit down those holes.
    SOME “micro” (1/8”/5mm) bit holders will fit.
    Fred Cisin - crwdns2934203:0crwdne2934203:0
  3. Ryobi P501G Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P501G Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the top side of the encasement to reveal the internal parts of the saw.
    • Locate the motor.
  4. Ryobi P501G Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P501G Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T15 torx screwdriver, unscrew all four of the screws to free the motor from the encasement.
    It is NOT a “standard” screwdriver. It is a T15 Torx.
  5. Ryobi P501G Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor and replace with a new one if needed.
    • Be careful when handling the motor- it may be very dirty/greasy. You might want to wear gloves for this step!
    The wires may not be detachable. MOST of the replacement motors have tabs for spade lug connectors, so you can cut the existing wires, strip them and solder or crimp spade lug connectors on. If the replacement motor also has attached wires, you will have to cut them and splice to the old wires.
Sophia Arias
crwdns2935283:004/21/19crwdne2935283:0
255 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G2, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S1-G2, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S1G2
Where can I find Ryobi circular saw motor Part #206216001? Thanks.
De-Hong Tang - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,186
