This guide will help the user disassemble the drill, replace the broken or worn out reverse switch, and reassemble the drill.
Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
Remove all ten Torx screws from the drill's case.
Remove the trigger so that it can fully expose the reverse switch.
Firmly grab the reverse switch and pull on it until it comes out of its socket.
